there was some talk about fixed gear bikes down at the island.
here's a couple of pics of mine - plus a pic of the original bike as ebay purchased for $47.
the general consensus is to start with a steel frame. its a pretty easy conversion - remove everything that you can (hardcore idiots run no brake at all), then either buy a new wheel set or get a track hub laced into your existing rear wheel. i did the latter.
my first bars where the originals flipped over and cut down into bullhorn style - but i couldn't get my shoulders comfortable. the current versions are $10 mountain bike riser bars - that i shortened by about 3" per side - and a $5 bmx brake lever. (again - ebay is your friend)
they are really nice bikes to ride - the absence of a deraillieur and perfectly aligned f and r chain rings makes quite a difference. it takes a little while to get used to no freewheel but it does improve your pedalling smoothness.
ps. the tattoo'd hipster at the bike shop added the red chain when building the rear wheel - he described it as 'spanky'. i think thats good...
