1973 Window frames
    1973 Window frames
    Hi all
    My 1973 is about to go off and be dipped and am wondering whetehr it is worth trying to save the window frames?
    Can these be polished? or are they chromed?
    Thanks in advance.
    Adam
    1. You need to disassemble completely and remove all threaded pieces as anodise stripping will destroy anything you leave behind
    2 Take to Melbourne Anodizing to remove the anodizing
    3 You need a mirror finish via a polisher, no scratching of any sort or any level, the polishing is critical to end result. Good luck finding a polisher.
    4. Take back to Melbourne Anodizing in Clayton to be anodised in bright anodising.= and pray your polisher did an awesome job.
    5. Reassemble
    6. Re insatall
    Quite task and not cheap
      Thank you Clyde.
      Is this the same procees for the front windscreen and rear window surrounds as well? Is there anything else i need to include in this process?
      Adam
        Hi Adam,
        Yes but cheaper and easier to buy new front and rear windscreen surrounds.
          Well worth the effort as Clyde says as well as the 1/4 windows being re chromed and the external door top rail and the 1/4 window alloy trim and the ...
